Generate Service From Oriented Imagery Dataset (Oriented Imagery Tools)
Summary
Generates a hosted feature service with an oriented imagery layer from an input oriented imagery dataset.
Usage
  • The tool allows you to customize settings when publishing an oriented imagery dataset as an oriented imagery layer to ArcGIS Online or an ArcGIS Enterprise portal. Oriented imagery layers cannot be created in ArcGIS Enterprise portals earlier than 11.2. This tool is an alternative to the standard ArcGIS Pro sharing workflow that includes oriented imagery-specific options.
  • This tool can be used to publish local image files as feature attachments to the oriented imagery layer. This allows you to store the images as part of the oriented imagery feature service, and control access to the images using layer permissions.
  • The oriented imagery viewer supports services with TIFF and JPG image formats as attachments. The maximum file size that can be uploaded is 2 GB.
Parameters
Label Explanation Data type
Input Oriented Imagery Dataset
The input oriented imagery dataset from which the hosted feature service will be created.
Oriented Imagery Layer
Output Service Name
The name of the output feature service that will be created.
String
Portal Folder
(Optional)
The folder in the ArcGIS Online or ArcGIS Enterprise portal where the service will be added.
String
Share With
(Optional)
Specifies the sharing level of the output service item.
  • Private—Only the owner of the item will have access. This is the default.
  • Organization—All members of your organization will have access
  • Public—People outside your organization will have access
String
Add footprint layer to the service
Specifies whether the footprint layer will be added to the output service.
  • Checked—The feature class defined in the Footprint Item property of the dataset will be added to the service as a sublayer. This is the default.
  • Unchecked—The footprint layer will not be added to the service.
Boolean
Add images as attachments
(Optional)
Specifies whether images will be added as attachments to the output service. Images can only be added as attachments when the images are on local disk or network storage.
  • Checked—The images referenced in the ImagePath field of the oriented imagery dataset will be added to the service as attachments.
  • Unchecked—The images will not be added to the service as attachments. This is the default.
Boolean
Tags
(Optional)
The service item tags separated by commas.
String
Summary
(Optional)
A summary of the service item
String
Virtual Cache Directory
(Optional)
The location of the cloud store registered on the server.
The parameter is available only when a valid cloud store has been configured in the ArcGIS Enterprise portal. The cloud store can be selected from the list available on the server. Only the cloud stores supporting secured storage implementation will be available for selection.
String
Allow Deep Learning
(Optional)
Specifies whether the deep learning workflows can be run on the published service.
  • Checked—The deep learning workflows can be run on the published service.
  • Unchecked—The deep learning workflows cannot be run on the published service. This is the default.
Boolean
Derived output
Output Service Item
The path to the output feature service item.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
