An overview of the Analyze Patterns toolset
These tools identify, quantify, and visualize spatial patterns in data.
The raster analysis portal tools are available when you are signed in to an ArcGIS Enterprise portal that has ArcGIS Image Server configured for Raster Analysis. When a tool is run, ArcGIS Pro serves as a client and the processing occurs in the servers federated with ArcGIS Enterprise. The portal tools accept layers from your portal as input and creates output in your portal.
The tools will not work if your active portal is ArcGIS Online.
These tools can be accessed from either the Analysis ribbon or the Portal tab in the Geoprocessing pane.
Learn more about portal tools
Tool
Calculate Density
Creates a density map from point or line features by spreading known quantities of some phenomenon (represented as attributes of the points or lines) across the map. The result is a layer of areas classified from least dense to most dense.
Interpolate Points
Predicts values at new locations based on measurements from a collection of points. The tool takes point data with values at each point and returns a raster of predicted values.
Tools of the Analyze Patterns toolset
