An overview of the Generalize toolset
This tool generalizes or simplifies a raster layer.
The raster analysis portal tools are available when you are signed in to an ArcGIS Enterprise portal that has ArcGIS Image Server configured for Raster Analysis. When a tool is run, ArcGIS Pro serves as a client and the processing occurs in the servers federated with ArcGIS Enterprise. The portal tools accept layers from your portal as input and creates output in your portal.
The tools will not work if your active portal is ArcGIS Online.
These tools can be accessed from either the Analysis ribbon or the Portal tab in the Geoprocessing pane.
Learn more about portal tools
Tool
Nibble
Replaces cells of a raster corresponding to a mask with the values of the nearest neighbors.
Tools of the Generalize toolset
