Classify Pixels Using Deep Learning (Raster Analysis Tools)
Summary
Runs a trained deep learning model on an input image to produce a classified raster published as a hosted imagery layer in your portal.
Illustration
Classify Pixels Using Deep Learning tool illustration
Usage
  • The raster analysis (RA) server Python environment must be configured with the proper deep learning framework Python API such as CNTK or something similar.
  • With this tool running, your RA server calls a third-party deep learning Python API (such as CNTK) and uses the specified Python raster function to process each raster tile.
  • The input model of this tool will only take a deep learning package (.dlpk) item from the portal.
  • After the input model is selected or specified, the tool will obtain the model arguments information from the RA server. The tool may fail to obtain such information if your input model is invalid or your RA server isn't properly configured with the deep learning framework.
Parameters
Label Explanation Data type
Input Raster
The input image to classify. It can be an image service URL, a raster layer, an image service, a map server layer, or an Internet tiled layer.
Raster Layer; Image Service; Map Server; Map Server Layer; Internet Tiled Layer; String
Input Model
The input is a URL of a deep learning package (.dlpk) item. It contains the path to the deep learning binary model file, the path to the Python raster function to be used, and other parameters such as preferred tile size or padding.
File
Output Name
The name of the image service of the classified pixels.
String
Model Arguments
(Optional)
The function arguments are defined in the Python raster function class referenced by the input model. This is where you list additional deep learning parameters and arguments for experiments and refinement, such as a confidence threshold for adjusting the sensitivity. The names of the arguments are populated by the tool from reading the Python module on the RA server.
Value table columns:
  • Name—The name of the function argument.
  • Value—The value of the function argument.
Value Table
Processing Mode
(Optional)
Specifies how all raster items in a mosaic dataset or an image service will be processed. This parameter is applied when the input raster is a mosaic dataset or an image service.
  • Process as mosaicked image—All raster items in the mosaic dataset or image service will be mosaicked together and processed. This is the default.
  • Process all raster items separately—All raster items in the mosaic dataset or image service will be processed as separate images.
String
Derived output
Updated Input Raster
The output raster dataset.
Raster Layer
Environments
Cell Size, Extent, Output Coordinate System, Parallel Processing Factor, Processor Type, Snap Raster
Licensing information
  • Basic: Requires ArcGIS Image Server
  • Standard: Requires ArcGIS Image Server
  • Advanced: Requires ArcGIS Image Server
