Convert Feature To Raster (Raster Analysis Tools)
Summary
Converts features to a raster dataset.
Illustration
Usage
This raster analysis portal tool is available when you are signed in to an ArcGIS Enterprise portal that has ArcGIS Image Server configured for Raster Analysis. When the tool is run, ArcGIS Pro serves as a client and the processing occurs in the servers federated with ArcGIS Enterprise. The portal tool accepts layers from your portal as input and creates output in your portal.
The input feature layer can be a layer from the portal. It can also be a URI or URL to a feature service. This tool does not support local feature data and layers as input.
Point, line, or polygon features can be converted to a raster dataset.
Parameters
| Label | Explanation | Data type |
Input Features |
The input feature layer. |
Feature Set |
Value field |
Choose the field that will be used to assign values to the output raster. |
Field |
Output Name |
The name of the output raster service. The default name is based on the tool name and the input layer name. If the layer name already exists, you will be prompted to provide another name. |
String |
Output Cell Size |
Enter the cell size and unit for the output raster. The unit values are Kilometers, Meters, Statute Miles, International Feet, US Survey Miles, and US Survey Feet. The default units are meters. |
Linear Unit |
Derived output
Output Raster |
The output raster. |
Raster Layer |
Environments
Cell Size, Extent, Output Coordinate System, Pyramid, Snap Raster
Licensing information
- Basic: Requires ArcGIS Image Server
- Standard: Requires ArcGIS Image Server
- Advanced: Requires ArcGIS Image Server
