Output from Find Closest Facilities
Upon successful execution, the service returns the best route and travel directions between the incident and the chosen facility and displays the status indicating whether the analysis was successful using the following output parameters:
output_facilities and output_closest_facilities
This provides access to the output facilities from a closest facility analysis.
The output_closest_facilities parameter includes only those facilities from the set of input facilities that were closest to at least one incident. Conversely, the output_facilities data type includes all the facilities from the analysis including the facilities that cannot be reached from any of the incidents. You can use the Status field from the output_facilities data type to determine why a facility was not used in the analysis.
The following table lists the fields that are returned for output facilities:
Field name |
Description |
The name of the facility. The values for this field are copied from the |
The numeric identifier of the network dataset source feature class on which the input point is located. |
The ObjectID of the feature in the source on which the input point is located. |
The position along the digitized direction of the source line feature. This value is stored as a ratio. This field is null if the network location references a junction. |
The side of the edge in relation to the digitized direction of the line feature. This field is limited to a domain of two values: Right Side (1) and Left Side (2). |
The direction a vehicle may arrive at and depart from the facility. The values for this field are copied from the |
Specifies the status of the point with respect to its location on the network and the outcome of the analysis. The possible values are the following:
The x-coordinate of the position on the network dataset where the point was located, in the coordinate system of the network dataset. |
The y-coordinate of the position on the network dataset where the point was located, in the coordinate system of the network dataset. |
The z-coordinate of the position on the network dataset where the point was located, in the coordinate system of the network dataset. The |
The distance in meters between the point's geographic location and the position where it was located on the network. |
The amount of time added to the total route time when this facility is visited. The values for this field are copied from the |
The amount of distance added to the total route distance when this facility is visited. The values for this field are copied from the |
The cost added to the total route cost when this facility is visited. The values for this field are copied from the |
The impedance value at which the analysis stopped searching for the facilities from a given incident. The values for this field are copied from the |
A user-defined unique identifier for the facility. The values for this field are copied from the |
The Legacy:The |
output_routes
This provides access to the resulting route or routes between the facilities and the incidents.
The route_shape and route_line_simplification_tolerance parameters influence the shape of the output routes.
Field name |
Description |
The name of the closest facility route is based on the names of the associated facility and incident. The facility name is first if the value for the If |
The rank of the facility among all facilities found for the associated incident; the closest facility has a rank of 1. |
The user-defined unique ID of the facility the route visits. The values for this field are copied from the |
The |
The user-defined unique ID of the incident the route visits. The values for this field are copied from the |
The |
The side of the vehicle the facility is on when arriving at or departing from the facility. A value of 1 means the right side of vehicle; a value of 2 indicates the left side. |
The side of the vehicle the incident is on when arriving at or departing from the incident. A value of 1 means the right side of the vehicle; a value of 2 indicates the left side. |
The start time of the route, reported in the time zone in which the first stop is located. |
The end time of the route, reported in the time zone in which the last stop is located. |
The start time of the route in coordinated universal time (UTC). |
The end time of the route in coordinated universal time (UTC). |
The cumulative travel time in minutes of the route between the facility and the incident. This includes any Note:An additional field, Note:Additional fields, |
The cumulative travel distance in miles of the route between the facility and the incident. This includes any Note:An additional field, Note:Additional fields, |
The cumulative travel distance in kilometers of the route between the facility and the incident. This includes any Note:An additional field, Note:Additional fields, |
The cumulative travel cost in unknown units of the route between the facility and the incident. This includes any This field is included only when the travel mode used for the analysis has an impedance attribute that is neither time based nor distance based. Note:Additional fields |
output_incidents
This provides access to the locations used as starting or ending points in a closest facility analysis.
The following table lists the fields that are returned for output incidents:
Field |
Description |
The name of the incident. The values for this field are copied from the |
The number of facilities that need to be found for the given incident. The values for this field are copied from the |
The direction a vehicle may arrive at and depart from the incident. The values for this field are copied from the |
The amount of time added to the total route time when this incident is visited. The values for this field are copied from the |
The amount of distance added to the total route distance when this incident is visited. The values for this field are copied from the |
The cost added to the total route cost when this incident is visited. The values for this field are copied from the |
The impedance value at which the analysis stopped searching for the incidents from a given facility. The values for this field are copied from the |
The |
output_directions
This provides access to the turn-by-turn directions for each resulting route.
Legacy:
This output type has been superseded by the DirectionPoints and DirectionLines output classes, which should be used for all new scripts and workflows.
The shape for the directions feature is determined from the underlying streets included in the route.
The Directions Language, Directions Distance Units, and Directions Style Name parameters influence the travel directions. The parameter returns empty features if the Populate Directions parameter is set to False.
The following table lists the fields that are returned for output directions:
Field |
Description |
The name of the route to which the driving action applies. This value is the same as the |
The time of day to initiate the given driving action. If the route spans multiple days, the date and time of day are displayed. |
The type of maneuver that the directions feature represents or the type of the directions text. To determine whether
The Maneuver Types
Directions String Types
Specifies whether the
A text description of the travel directions. |
The time elapsed in minutes from when the current driving direction starts until the next one starts, or until the route ends for the last driving direction. |
The distance from where the current driving direction occurs to where the next one occurs, or to where the route ends for the last driving direction. The value is in the units specified by the This value is zero for driving directions that occur at the same location where the next one begins. For example, the |
output_direction_points
This is the output turn-by-turn directions for the routes calculated in the analysis, represented as point locations along the routes where specific direction events or maneuvers occur.
Field name |
Description |
The ObjectID of the output |
The sequence of the direction points for the route, starting with 1. |
Specifies the type of direction event or maneuver described by the point, designated by one of the values below.
The ObjectID of the stop with which this direction point is associated, if any. If the point does not represent a visit to a stop, the value is null. |
The directions text that will be displayed in the consuming application. |
The time the direction event occurs in coordinated universal time (UTC). |
The difference in minutes between the local time at the maneuver location and UTC time shown in the |
The name of the direction point. |
The highway exit name that appears in the directions instruction. |
The alternate source name that appears in the directions instruction. |
The name of the intersecting or cross street that appears in the directions instruction. |
The signpost branch name that appears in the directions instruction. |
The signpost toward destination name that appears in the directions instruction. |
The building level at which this direction event occurs. This value corresponds to the Learn more about the directions configuration of a network dataset |
The short text that will be used as voice guidance text in the consuming application. |
The additional text, including expanded abbreviations and plurals, that will be used as voice guidance text in the consuming application. |
The bearing in degrees of the vehicle departing this point. Zero indicates north. |
output_direction_lines
This is the output route lines calculated in the analysis sliced to represent each route segment between DirectionPoints events or maneuver locations.
Field name |
Description |
The ObjectID of the feature in the |
Specifies the type of direction situation described by this line, designated by one of the following values:
The length of the line segment measured in meters. |
The travel time along the line segment in minutes. |
The building level at which this direction event begins. This value corresponds to the Learn more about the directions configuration of a network dataset |
The building level at which this direction event ends. This value corresponds to the |
solve_succeeded
Use this parameter to determine if the analysis was successful.
output_route_data
Use this parameter to access a .zip file that contains a file geodatabase containing the inputs and outputs of the analysis in a format that can be used to share route layers with ArcGIS Online or Portal for ArcGIS. The parameter value is populated only when the Save Route Data parameter is set to True.
The file is downloaded to a temporary directory on your machine. In ArcGIS Pro, the location of the downloaded file can be determined by viewing the Output Route Data parameter value in the entry corresponding to the tool operation in the geoprocessing history of the project. In ArcMap, the location of the file can be determined by accessing the Copy Location option in the shortcut menu of the Output Route Data parameter in the entry corresponding to the tool operation in the Geoprocessing Results window.
output_result_file
Use this parameter to access the results from the analysis as a .zip file containing one or more files for each output. The format of the individual file is specified by the Output Format parameter. The parameter value is not populated when the Output Format parameter is set to Feature Set.
When a file-based output format—such as JSON File or GeoJSON File—is specified, no outputs are added to the display, since the application (such as ArcMap or ArcGIS Pro) does not draw the contents of the result file. Instead, the result file is downloaded to a temporary directory on your machine. In ArcGIS Pro, the location of the downloaded file can be determined by viewing the Output Result File parameter value in the entry corresponding to the tool operation in the geoprocessing history of the project. In ArcMap, the location of the file can be determined by accessing the Copy Location option in the shortcut menu of the Output Result File parameter in the entry corresponding to the tool operation in the Geoprocessing Results window.
output_network_analysis_layer
Use this parameter to access the network analysis layer file that stores the analysis settings and the inputs and outputs used for the analysis. The parameter value is populated only when the Save Output Network Analysis Layer parameter is set to True.
The file is downloaded to a temporary directory on your machine. In ArcGIS Pro, the location of the downloaded file can be determined by viewing the Output Network Analysis Layer parameter value in the entry corresponding to the tool operation in the geoprocessing history of the project. In ArcMap, the location of the file can be determined by accessing the Copy Location option in the shortcut menu of the Output Network Analysis Layer parameter in the entry corresponding to the tool operation in the Geoprocessing Results window.
You cannot work directly with this file even when you open the file in an ArcGIS Desktop application such as ArcMap since its data source will not be valid. The file is meant to be sent to Esri Technical Support to diagnose the quality of results returned from the tool.
