Output from Find Routes
Upon successful execution of FindRoutes, the service returns the best routes between the stops, and the status indicating whether the analysis was successful, using the output parameters described below.
output_routes
This provides access to the resulting routes.
The following table lists the fields returned for output routes:
Field
Name
The name of the route is based on the RouteName field of the associated stops. If the input RouteName field is null, the name is derived from the Name field of the first and last stops.
StopCount
The number of stops assigned to the route.
StartTime
The start time of the route, reported in the time zone in which the first stop is located.
EndTime
The end time of the route, reported in the time zone in which the last stop is located.
StartTimeUTC
The start time of the route in coordinated universal time (UTC).
EndTimeUTC
The end time of the route in coordinated universal time (UTC).
Total_Minutes
The cumulative travel time in minutes from the beginning of the first stop to the end of the last stop for a route. This includes any AdditionalTime values for the visited stops if specified.
An additional field, Total_[TimeUnits], is included if measurement_units is time based and its value is not set to Minutes. The field values are in the units specified by the measurement_units parameter.
Additional fields, Total_[AccumulateAttributeName]_[TimeUnits], are included for each time-based cost attribute that is accumulated during the analysis.
Total_Miles
The cumulative travel distance in miles from the beginning of the first stop to the end of the last stop for a route. This includes any AdditionalDistance values for the visited stops if specified.
An additional field, Total_[DistanceUnits], is included if the measurement_units parameter is distance based and its value is not Miles or Kilometers. The field values are in the units specified by the measurement_units parameter.
Additional fields, Total_[AccumulateAttributeName]_[DistanceUnits], are included for each distance-based cost attribute that is accumulated during the analysis.
Total_Kilometers
The cumulative travel distance in kilometers from the beginning of the first stop to the end of the last stop for a route. This includes any AdditionalDistance values for the visited stops if specified.
Total_Other
The cumulative travel cost in unknown units from the beginning of the first stop to the end of the last stop for a route. This includes any AdditionalCost values for the visited stops if specified.
This field is included only when the travel mode used for the analysis has an impedance attribute that is neither time based nor distance based.
Additional fields, Total_[AccumulateAttributeName]_Other, are included for each cost attribute that is neither time based nor distance based and accumulated during the analysis.
TotalWait_Minutes
This field stores the route's overall wait time, which is the time spent at stops waiting for time windows to open.
The field has a null value if time windows are not used in the analysis.
An additional field, TotalWait_[TimeUnits], is included if the measurement_units parameter is not set to Minutes. The field values are in the units specified by the measurement_units parameter.
Additional fields, TotalWait_[AccumulateAttributeName]_[TimeUnits], are included for each time-based cost attribute that is accumulated during the analysis.
TotalViolation_Minutes
This field stores the route's overall violation time at stops. Violation time is added when the route arrives at a stop after the time window has ended; it's the difference between the ArriveTime and TimeWindowEnd field values on inputs stops.
An additional field, TotalViolation_[TimeUnits], is included if the timeUnits property of the analysis object is not set to TimeUnits.Minutes. The field values are in the units specified by the timeUnits property.
Additional fields, TotalViolation_[AccumulateAttributeName]_[TimeUnits], are included for each time-based cost attribute that is accumulated during the analysis.
FirstStopID
The unique identifier automatically generated by the analysis of the first stop on the route.
FirstStopOID
The ObjectID value of the first stop on the route. This field is often used to join information from input stops to routes.
LastStopID
The unique identifier automatically generated by the analysis of the last stop on the route.
LastStopOID
The ObjectID value of the last stop on the route. This field is often used to join information from input stops to routes.
output_directions
This provides access to the turn-by-turn directions for each resulting route.
Legacy:
This output type has been superseded by the DirectionPoints and DirectionLines output classes, which should be used for all new scripts and workflows.
The shape for the directions feature is determined from the underlying streets included in the route.
The Directions Language, Directions Distance Units, and Directions Style Name parameters influence the travel directions. The parameter returns empty features if the Populate Directions parameter is set to False.
The following table lists the fields that are returned for output directions:
Field
RouteName
The name of the route to which the driving action applies. This value is the same as the Name field of the output routes.
ArriveTime
The time of day to initiate the given driving action. If the route spans multiple days, the date and time of day are displayed.
Type
The type of maneuver that the directions feature represents or the type of the directions text. To determine whether Type refers to a maneuver type or a directions string type, review the SubItemType field value.
Type can be used, for example, to assign an icon for direction text based on the maneuver type, or it can use a formatting style based on the directions string type when displaying the driving directions in the application.
The Type value is an integer from the Maneuver Types or Directions String Types lists below.
Maneuver Types
  • 0: Unknown
  • 1: Arrive at Stop
  • 2: Go straight
  • 3: Bear left
  • 4: Bear right
  • 5: Turn left
  • 6: Turn right
  • 7: Make sharp left
  • 8: Make sharp right
  • 9: Make U-turn
  • 10: Take ferry
  • 11: Take roundabout
  • 12: Merge to highway
  • 13: Exit highway
  • 14: Go on another highway
  • 15: At fork keep center
  • 16: At fork keep left
  • 17: At fork keep right
  • 18: Depart stop
  • 19: Trip planning item
  • 20: End of ferry
  • 21: Ramp right
  • 22: Ramp left
  • 23: Turn left and immediately turn right
  • 24: Turn right and immediately turn left
  • 25: Turn right and immediately turn right
  • 26: Turn left and immediately turn left
  • 27: Pedestrian ramp
  • 28: Elevator
  • 29: Escalator
  • 30: Stairs
  • 31: Door passage
  • 0: General directions string type
  • 1: Depart directions string type
  • 2: Arrive directions string type
  • 3: Length directions string type
  • 4: Time directions string type
  • 5: Time summary directions string type
  • 6: Time Window directions string type
  • 7: Violation Time directions string type
  • 8: Wait Time directions string type
  • 9: Service Time directions string type
  • 10: Estimated Arrival Time directions string type
  • 11: Cumulative Length directions string type
  • 12: Street name directions string type
  • 13: Alternate street name directions string type
  • 14: Sign branch information directions string type
  • 15: Sign toward information directions string type
  • 16: Cross street name directions string type
  • 17: Sign exit number directions string type
SubItemType
Specifies whether the Type field refers to an integer from the Directions String Types table or the Maneuver Types table.
  • If the SubItemType value is 1, the Type field refers to the values from the Maneuver Types table.
  • If the SubItemType value is 2, the Type field refers to the values from the Directions String Types table.
  • If the SubItemType value is 3, the Type field refers to the values from the Directions String Types table.
Text
A text description of the travel directions.
ElaspsedTime
The time elapsed in minutes from when the current driving direction starts until the next one starts, or until the route ends for the last driving direction.
DriveDistance
The distance from where the current driving direction occurs to where the next one occurs, or to where the route ends for the last driving direction.
The value is in the units specified by the Directions_Distance_Units parameter.
This value is zero for driving directions that occur at the same location where the next one begins. For example, the DriveDistance value is 0 for the directions text at the start of the route.
output_direction_points
This is the output turn-by-turn directions for the routes calculated in the analysis, represented as point locations along the routes where specific direction events or maneuvers occur.
Field name
RouteID
The ObjectID of the output output_routes feature with which this direction point is associated.
Sequence
The sequence of the direction points for the route, starting with 1.
DirectionPointType
Specifies the type of direction event or maneuver described by the point, designated by one of the values below.
  • Header (1)
  • Arrive (50)
  • Depart (51)
  • Straight (52)
  • On Ferry (100)
  • Off Ferry (101)
  • Central Fork (102)
  • Roundabout (103)
  • U-Turn (104)
  • Door (150)
  • Stairs (151)
  • Elevator (152)
  • Escalator (153)
  • Pedestrian Ramp (154)
  • Left Fork (200)
  • Left Ramp (201)
  • Clockwise Roundabout (202)
  • Left-handed U-turn (203)
  • Bear left (204)
  • Left Turn (205)
  • Sharp Left (206)
  • Left Turn and immediate Left Turn (207)
  • Left Turn and immediate Right Turn (208)
  • Right Fork (300)
  • Right Ramp (301)
  • Counter-Clockwise Roundabout (302)
  • Right-handed U-turn (303)
  • Bear right (304)
  • Right Turn (305)
  • Sharp Right (306)
  • Right Turn and immediate Left Turn (307)
  • Right Turn and immediate Right Turn (308)
  • Up Elevator (400)
  • Up Escalator (401)
  • Up Stairs (402)
  • Down Elevator (500)
  • Down Escalator (501)
  • Down stairs (502)
  • General Event (1000)
  • Landmark (1001)
  • Time Zone Change (1002)
  • Traffic Event (1003)
  • Scaled Cost Barrier Event (1004)
  • Boundary Crossing (1005)
  • Restriction Violation (1006)
  • Lane (1007)
StopID
The ObjectID of the stop with which this direction point is associated, if any. If the point does not represent a visit to a stop, the value is null.
DisplayText
The directions text that will be displayed in the consuming application.
ArrivalTime
The time the direction event occurs in coordinated universal time (UTC).
ArrivalUTCOffset
The difference in minutes between the local time at the maneuver location and UTC time shown in the ArrivalTime field.
Name
The name of the direction point.
ExitName
The highway exit name that appears in the directions instruction.
AlternateName
The alternate source name that appears in the directions instruction.
IntersectingName
The name of the intersecting or cross street that appears in the directions instruction.
BranchName
The signpost branch name that appears in the directions instruction.
TowardName
The signpost toward destination name that appears in the directions instruction.
Level
The building level at which this direction event occurs. This value corresponds to the Level property defined in the network dataset used for the analysis.
Learn more about the directions configuration of a network dataset
ShortVoiceInstruction
The short text that will be used as voice guidance text in the consuming application.
VoiceInstruction
The additional text, including expanded abbreviations and plurals, that will be used as voice guidance text in the consuming application.
Azimuth
The bearing in degrees of the vehicle departing this point. Zero indicates north.
output_direction_lines
This is the output route lines calculated in the analysis sliced to represent each route segment between DirectionPoints events or maneuver locations.
Field name
DirectionPointID
The ObjectID of the feature in the output_direction_points table with which this line is associated.
RouteID
The ObjectID of the output output_routes feature with which this direction line is associated.
DirectionLineType
Specifies the type of direction situation described by this line, designated by one of the following values:
  • Unknown (0)
  • Segment (1)
  • Maneuver Segment (2)
  • Restriction violation (3)
  • Scaled Cost Barrier (4)
  • Heavy Traffic (5)
  • Slow Traffic (6)
  • Moderate Traffic (7)
Meters
The length of the line segment measured in meters.
Minutes
The travel time along the line segment in minutes.
FromLevel
The building level at which this direction event begins. This value corresponds to the Level property defined in the network dataset used for the analysis.
ToLevel
The building level at which this direction event ends. This value corresponds to the Level property defined in the network dataset used for the analysis.
output_stops
This provides access to the attributes of the stops that are visited by the routes as well as stops that cannot be reached by any of the routes.
You can use the attributes from this parameter, such as the Status field, to determine why a stop was not assigned to any routes.
The following table list the fields returned for output stops. In addition to these fields, the parameter also includes all the fields from the input feature class used as stops for the analysis.
Field
Name
The name of the stop visited by the route. The values for this field are copied from the Name field on the input stops.
RouteName
The name of the route to which the stop is assigned.
Input stops that have the same route name at the time the tool runs are grouped together and visited by one route, and the route is assigned that name. When more than one route name is present on the input stops, the tool can output multiple routes—one for each unique route name.
If no name is provided, all the stops belong to the same route.
Sequence
The order in which the stops are visited by the assigned route, which is listed in the RouteName field.
TimeWindowStart
The earliest time the route can visit the stop. The values for this field are copied from the TimeWindowStart field on the input stops.
TimeWindowEnd
The latest time the route can visit the stop. The values for this field are copied from the TimeWindowEnd field on the input stops.
ArriveCurbApproach
The side of the vehicle the curb is on when arriving at the stop.
DepartCurbApproach
The side of the vehicle the curb is on when departing from the stop.
ArriveTime
The date and time value indicating the arrival time at the stop. The time zone for this time-of-day value is taken from the network element on which the stop is located.
DepartTime
The date and time value indicating the departure time from the stop. The time zone for this time-of-day value is taken from the network element on which the stop is located.
ArriveTimeUTC
DepartTimeUTC
The date and time value indicating the departure time in coordinated universal time (UTC)
LocationType
The stop type. The values for this field are copied from the LocationType field on the input stops.
SourceID
The numeric identifier of the network dataset source feature class on which the input point is located.
SourceOID
The ObjectID of the feature in the source on which the input point is located.
PosAlong
The position along the digitized direction of the source line feature. This value is stored as a ratio. This field is null if the network location references a junction.
SideOfEdge
The side of the edge in relation to the digitized direction of the line feature. This field is limited to a domain of two values: Right Side (1) and Left Side (2).
CurbApproach
The direction a vehicle may arrive at and depart from the stop. The values for this field are copied from the CurbApproach field on the input stops.
Status
Specifies the status of the point with respect to its location on the network and the outcome of the analysis. The possible values are the following:
  • 0 (OK)—The point was located on the network.
  • 1 (Not Located)—The point was not located on the network and was not included in the analysis.
  • 2 (Network element not located)—The network element identified by the point's network location fields can't be found. This can occur when a network element where the point should be was deleted, and the network location was not recalculated.
  • 3 (Element not traversable)—The network element that the point is located on is not traversable. This can occur when the element is restricted by a restriction attribute.
  • 4 (Invalid Field Values)—Field values fall outside a range or coded-value domain. For example, a negative number exists where positive numbers are required.
  • 5 (Not Reached)—The point can't be reached by the solver. The point may be on a separate, disconnected area of the network from the other inputs, or barriers or restrictions prevent travel to or from the point.
  • 6 (Time window violation)—The point could not be reached within the designated time windows. This status only applies to network analysis types that support time windows.
  • 7 (Not located on closest)—The closest network location to the point is not traversable because of a restriction or barrier, so the point has been located on the closest traversable network feature instead.
SnapX
The x-coordinate of the position on the network dataset where the point was located, in the coordinate system of the network dataset.
SnapY
The y-coordinate of the position on the network dataset where the point was located, in the coordinate system of the network dataset.
SnapZ
The z-coordinate of the position on the network dataset where the point was located, in the coordinate system of the network dataset. The SnapZ field is 0 if the network is two dimensional.
DistanceToNetworkInMeters
The distance in meters between the point's geographic location and the position where it was located on the network.
AdditionalTime
The amount of time added to the total route time when this stop is visited. The values for this field are copied from the AdditionalTime field on the input stops.
AdditionalDistance
The amount of distance added to the total route distance when this stop is visited. The values for this field are copied from the AdditionalDistance field on the input stops.
AdditionalCost
The cost added to the total route cost when this stop is visited. The values for this field are copied from the AdditionalCost field on the input stops. This field is included only when the travel mode used for the analysis has an impedance attribute that is neither time based nor distance based.
Cumul_Minutes
The cumulative duration of the route in minutes from the origin to and including the stop. The value reported here is the cumulative route time to the stop, including any additional time at the stop and at any previous stops.
For example, if a route analysis determines that it takes 10 minutes to visit two stops, and the second stop has an AdditionalTime value of 5, the Cumul_Minutes value will be 15 minutes.
An additional field, Cumul_[TimeUnits], is included if the measurement_units parameter is time based and its value is not set to Minutes. The field values are in the units specified by the measurement_units parameter.
Additional fields, Cumul_[AccumulateAttributeName]_[TimeUnits], are included for each time-based cost attribute that is accumulated during the analysis.
Cumul_Miles
The cumulative distance of the route in miles from the origin to and including the stop. The value reported here is the cumulative route distance to the stop, including any additional distance at the stop and at any previous stops.
An additional field, Cumul_[DistanceUnits], is included if the measurement_units parameter is distance based and its value is not Miles or Kilometers. The field values are in the units specified by the measurement_units parameter.
Additional fields, Cumul_[AccumulateAttributeName]_[DistanceUnits], are included for each distance-based cost attribute that is accumulated during the analysis.
Cumul_Kilometers
The cumulative distance of the route in kilometers from the origin to and including the stop. The value reported here is the cumulative route distance to the stop, including any additional distance at the stop and at any previous stops.
Cumul_Cost
The cumulative cost of the route from the origin to and including the stop. The value reported here is the cumulative route cost to the stop, including any additional cost at the stop and at any previous stops. This field is included only when the travel mode used for the analysis has an impedance attribute that is neither time based nor distance based. The value is in unknown units.
Additional fields, Cumul_[AccumulateAttributeName]_Other, are included for each cost attribute that is neither time based nor distance based and accumulated during the analysis.
Wait_Minutes
This field stores the time spent waiting for the time window to open when the route arrives early at the stop.
An additional field, Wait_[TimeUnits], is included if the measurement_units parameter is time based and its value is not set to Minutes. The field values are in the units specified by the measurement_units parameter.
Additional fields, Wait_[AccumulateAttributeName]_[TimeUnits], are included for each time-based cost attribute that is accumulated during the analysis.
CumulWait_Minutes
This field stores the sum of how much time has been spent waiting for time windows to open. It measures idle time. It includes the wait time from the current stop and all previous stops visited by the route.
An additional field, CumulWait_[TimeUnits], is included if the measurement_units parameter is time based and its value is not set to Minutes. The field values are in the units specified by the measurement_units parameter.
Additional fields, CumulWait_[AccumulateAttributeName]_[TimeUnits], are included for each time-based cost attribute that is accumulated during the analysis.
Violation_Minutes
This field is a measure of how late the route arrived after the time window closed. Specifically, it stores the amount of time between the end of the time window and when the route arrived at the stop.
An additional field, Violation_[TimeUnits], is included if the measurement_units parameter is time based and its value is not set to Minutes. The field values are in the units specified by the measurement_units parameter.
Additional fields Violation_[AccumulateAttributeName]_[TimeUnits] are included for each time-based cost attribute that is accumulated during the analysis.
CumulViolation_Minutes
This field stores the cumulative violation time from the current stop and all previous stops visited by the route.
An additional field, CumulViolation_[TimeUnits], is included if the measurement_units parameter is time based and its value is not set to Minutes. The field values are in the units specified by the measurement_units parameter.
An additional field CumulViolation_[TimeUnits] is included if the timeUnits property of the analysis object is not set to TimeUnits.Minutes. The field values are in the units specified by the timeUnits property.
Additional fields CumulViolation_[AccumulateAttributeName]_[TimeUnits] are included for each time-based cost attribute that is accumulated during the analysis.
ORIG_FID
The ObjectID value of the input stop. This field can be used to join attributes from the output stops to the input stops or from the input stops to the output stops.
Bearing
The values for this field are copied from the Bearing field on the input stops.
BearingTol
The values for this field are copied from the BearingTol field on the input stops.
NavLatency
The values for this field are copied from the NavLatency field on the input stops.
output_route_edges
This provides access to the individual network edges along which the routes travel.
This parameter has value only when the populate_route_edges parameter is set to True.
The following table lists the fields supported by the output route edges:
Field
SourceName
The name of the edge source feature class from which the line was generated.
SourceOID
The ObjectID value of the traversed street feature. Summarizing the values for this field can provide useful information such as the number of times a particular street feature is included in all the routes.
RouteEdgeID
The ID representing the edge that comprises the street feature. Since there can be more than one edge per street feature, the SourceOID field can be used to uniquely identify the traversed street feature, and the RouteEdgeID field can be used to uniquely identify the edge within the traversed street feature.
FromPosition
Specifies where the output RouteEdges feature begins in reference to the digitized direction of the underlying street feature.
  • A value of 0 (zero) indicates that the line begins at the from point of the underlying street feature.
  • A value of 1 indicates that the line begins at the to point of the street feature.
  • A value between 0 and 1 indicates that the line begins at a point along the underlying street feature; for example, a value of 0.25 means the line begins 25 percent along the digitized direction of the underlying street feature.
ToPosition
Specifies where the output RouteEdges feature ends in reference to the digitized direction of the underlying street feature.
  • A value of 0 (zero) indicates that the line ends at the from point of the underlying street feature.
  • A value of 1 indicates that the line ends at the to point of the street feature.
  • A value between 0 and 1 indicates that the line ends at a point along the underlying street feature; for example, a value of 0.25 means the line ends 25 percent along the digitized direction of the underlying street feature.
FromJunctionID
The ObjectID of the feature in the RouteJunctions feature class that is coincident with the beginning of the RouteEdges feature.
ToJunctionID
The ObjectID of the feature in the RouteJunctions feature class that is coincident with the end of the RouteEdges feature.
RouteID
Uniquely identifies the route that traversed the edge.
The RouteID value corresponds to an ObjectID value from the output routes.
Attr_Minutes
The travel time in minutes of the traversed portion of the underlying street feature.
An additional field, Attr_[TimeUnits], is included if the measurement_units parameter is time based and its value is not set to Minutes. The field values are in the units specified by the measurement_units parameter.
Attr_Miles
The length in miles of the traversed portion of the underlying street feature.
An additional field, Attr_[DistanceUnits], is included if the measurement_units parameter is distance based and its value is not Miles or Kilometers. The field values are in the units specified by the measurement_units parameter.
Attr_Kilometers
The length in kilometers of the traversed portion of the underlying street feature.
Attr_Other
The travel cost of the traversed portion of the underlying street feature. This field is included only when the travel mode used for the analysis has an impedance attribute that is neither time based nor distance based. The value is in unknown units.
Additional fields, Attr_[AccumulateAttributeName], are included for each cost attribute that is neither time based nor distance based and accumulated during the analysis.
Cumul_Minutes
The travel time in minutes of the route from its origin to the end of the traversed portion of this underlying street feature.
Additional fields, Cumul_[AccumulateAttributeName], are included for each time-based cost attribute that is accumulated during the analysis. The values are in the time units used for the analysis.
Cumul_Miles
The length in miles of the route from its origin to the end of the traversed portion of this underlying street feature.
Additional fields, Cumul_[AccumulateAttributeName], are included for each distance-based cost attribute that is accumulated during the analysis. The values are in the distance units used for the analysis.
Cumul_Kilometers
The length in kilometers of the route from its origin to the end of the traversed portion of this underlying street feature.
Cumul_Other
The travel cost of the route from its origin to the end of the traversed portion of this underlying street feature. This field is included only when the travel mode used for the analysis has an impedance attribute that is neither time based nor distance based. The value is in unknown units.
Additional fields, Cumul_[AccumulateAttributeName], are included for each cost attribute that is neither time based nor distance based and accumulated during the analysis.
Attr_[Soft Restriction Attribute Name]
Specifies whether the traversed edge used the soft restriction attribute referred to in this field's name.
  • 0—The traversed edge didn't use the soft restriction.
  • 1—The traversed edge used the soft restriction.
For example, if the analysis was performed using the soft restriction called Avoid Toll Roads, a field called Attr_Avoid_Toll_Roads is created for this soft restriction. A value of 1 for this field would represent the toll roads in the route.
solve_succeeded
Use this parameter to determine if the analysis was successful.
output_result_file
Use this parameter to access the results from the analysis as a .zip file containing one or more files for each output. The format of the individual file is specified by the Output Format parameter. The parameter value is not populated when the Output Format parameter is set to Feature Set.
When a file-based output format—such as JSON File or GeoJSON File—is specified, no outputs are added to the display, since the application (such as ArcMap or ArcGIS Pro) does not draw the contents of the result file. Instead, the result file is downloaded to a temporary directory on your machine. In ArcGIS Pro, the location of the downloaded file can be determined by viewing the Output Result File parameter value in the entry corresponding to the tool operation in the geoprocessing history of the project. In ArcMap, the location of the file can be determined by accessing the Copy Location option in the shortcut menu of the Output Result File parameter in the entry corresponding to the tool operation in the Geoprocessing Results window.
output_route_data
Use this parameter to access a .zip file that contains a file geodatabase containing the inputs and outputs of the analysis in a format that can be used to share route layers with ArcGIS Online or Portal for ArcGIS. The parameter value is populated only when the Save Route Data parameter is set to True.
The file is downloaded to a temporary directory on your machine. In ArcGIS Pro, the location of the downloaded file can be determined by viewing the Output Route Data parameter value in the entry corresponding to the tool operation in the geoprocessing history of the project. In ArcMap, the location of the file can be determined by accessing the Copy Location option in the shortcut menu of the Output Route Data parameter in the entry corresponding to the tool operation in the Geoprocessing Results window.
output_network_analysis_layer
Use this parameter to access the network analysis layer file that stores the analysis settings and the inputs and outputs used for the analysis. The parameter value is populated only when the Save Output Network Analysis Layer parameter is set to True.
The file is downloaded to a temporary directory on your machine. In ArcGIS Pro, the location of the downloaded file can be determined by viewing the Output Network Analysis Layer parameter value in the entry corresponding to the tool operation in the geoprocessing history of the project. In ArcMap, the location of the file can be determined by accessing the Copy Location option in the shortcut menu of the Output Network Analysis Layer parameter in the entry corresponding to the tool operation in the Geoprocessing Results window.
You cannot work directly with this file even when you open the file in an ArcGIS Desktop application such as ArcMap since its data source will not be valid. The file is meant to be sent to Esri Technical Support to diagnose the quality of results returned from the tool.
