Analyze Control Points (Reality Mapping Tools)
Summary
Analyzes the control point coverage and identifies the areas that need additional control points to improve the block adjust result.
The tool will check each image and provide the following:
  • The number of control points for each image
  • The percentage of image covered by the control points (point distribution)
  • The overlap areas
  • The number of control points within overlap areas
Usage
  • You can specify a mask to either exclude or include certain areas.
  • Specify a minimum overlap area so you do not end up with small slivers to analyze.
Parameters
Label Explanation Data type
Input Mosaic Dataset
The input mosaic dataset against which to analyze the control points.
Mosaic Dataset; Mosaic Layer
Input Control Points
The input control point feature class.
It is normally created from the Compute Tie Points or the Compute Control Points tool.
Feature Layer
Output Control Point Coverage Feature Class
A polygon feature class output that contains the control point coverage and the percentage of the area within the corresponding image.
Feature Class
Output Overlap Feature Class
A polygon feature class output that contains all the overlap areas between images.
Feature Class
Input Mask
(Optional)
A polygon feature class used to exclude areas that you do not want in the analysis of the control points computation.
The mask field can control the inclusion or exclusion of areas. A value of 1 indicates that the areas defined by the polygons (inside) will be excluded from the computation. A value of 2 indicates the defined polygons (inside) will be included in the computation while areas outside of the polygons will be excluded.
Feature Layer
Minimum Overlap Area
(Optional)
Specify the minimum percent that the overlap area must be, in relation to the image. Areas that are lower than the specified percent threshold will be excluded from the analysis.
Ensure that you do not have areas that are too small; otherwise, you will have small slivers being analyzed.
Double
Maximum Overlap Level
(Optional)
The maximum number of images that can be overlapped when analyzing the control points.
For example, if there are four images in your mosaic dataset, and a maximum overlap value of 3 was specified, then there are ten different combinations that will appear in the Overlap Window. If the four images were named i1, i2, i3, and i4, the ten combinations that would appear are [i1, i2, i3], [i1 i2 i4], [i1 i3 i4], [i2 i3 i4], [i1, i2], [i1, i3], [i1, i4], [i2, i3], [i2, i4], and [i3, i4].
Long
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
