Export Map Server Cache (Server Tools)
Summary
Exports tiles from a map image layer cache as a cache dataset or tile package to a folder on disk. The tiles can be imported into other caches, or they can be accessed from ArcGIS Desktop or mobile devices as a raster dataset, independent from their parent service.
Usage
  • Before running this tool, create the folder on disk that will hold the exported tiles.
  • The ArcGIS Server account must have write access to the target cache folder. If the ArcGIS Server account cannot be granted write access to the target cache folder, but the ArcGIS Pro client has write access to it, check the Copy data from server parameter.
  • The Overwrite Tiles parameter allows the exported tiles to completely overwrite the tiles in the destination cache, rather than blending the images. Exported tiles can still be constrained to an area of interest.
  • When the Ready To Serve Format parameter is checked, the cache content is generated using the open tile package specification. The cache format is Compact V2, but the cache schema is stored in JSON instead of XML. This cache content can be packaged to a zip archive as a tile package for publishing and offline workflows. This cache content is ready to serve using the workflows described in the Publish a tile layer from a cache dataset topic. This parameter is available only when the Export cache type parameter value is Cache dataset.
Parameters
Label Explanation Data type
Input Service
The map image layer with the cache tiles to be exported. You can choose it by browsing to the service in a portal or you can drag a web tile layer from the Portal tab in the Project pane to supply this parameter value.
Image Service; Map Server
Target Cache Path
The folder into which the cache will be exported. This folder does not need to be a registered server cache directory. The ArcGIS Server account must have write access to the target cache folder. If the server account cannot be granted write access to the target cache folder but the ArcGIS Desktop or ArcGIS Pro client has write access to it, check the Copy data from server parameter.
Folder
Export cache type
Specifies the type of cache that will be exported. Tile packages are suitable for use with ArcGIS Maps SDKs for Native Apps.
  • Cache dataset—A map or image service cache that is generated using ArcGIS Server will be exported. It can be used in ArcGIS Desktop and by ArcGIS Server map or image services. This option allows you to generate the content in a ready-to-serve format. This is the default.
  • Tile package—A single compressed file in which the cache dataset is added as a layer and consolidated so that it can be shared will be exported. In can be used in ArcGIS Pro and with ArcGIS Maps SDKs for Native Apps.
String
Specifies how tiles will be moved to the target folder.
Check this parameter if the ArcGIS Server account cannot be granted write access to the target folder and the ArcGIS Desktop or ArcGIS Pro client has write access to it. The software exports the tiles in the server output directory before moving them to the target folder.
  • Checked—Tiles will first be placed in the server output directory, then moved to the target folder. The ArcGIS Desktop or ArcGIS Pro client must have write access to the target folder.
  • Unchecked—Tiles will be exported directly into the target folder. The ArcGIS Server account must have write access to the target folder. This is the default.
Boolean
Storage Format Type
Specifies the storage format that will be used for the exported cache.
  • Compact—Tiles will be grouped in bundle and bundlex files to save space on disk and allow for faster copying of caches. If the Export cache type parameter is set to Tile package, this is the default.
  • Compact V2—Tiles will be grouped in bundle files only. This format provides better performance on network shares and cloud store directories. If the Export cache type parameter is set to Tile package, the extension of the tile package will be .tpkx, which is supported by recent versions of ArcGIS products such as ArcGIS Online, ArcGIS Enterprise 12.0, ArcGIS Maps SDKs for Native Apps 200.0 or later, and ArcGIS Runtime 100.5-100.15.
  • Exploded—Each tile will be stored as an individual file.
String
Scales
A list of scale levels at which tiles will be exported.
Double
Number of caching service instances
(Optional)
The number of instances that will be used to update or generate the tiles. The value for this parameter is set to unlimited (-1) and cannot be modified.
Long
Area Of Interest
(Optional)
An area of interest that spatially constrains where tiles will be exported from the cache. This parameter is useful when exporting irregularly shaped areas, as the tool clips the cache dataset at pixel resolution.
If you do not specify an area of interest, the full extent of the map will be exported.
Feature Set
Export Extent
(Optional)
A rectangular extent defining the tiles that will be exported. By default, the extent is set to the full extent of the map service into which you are importing. The optional Area Of Interest parameter allows you to alternatively import using a polygon. It is recommended that you not provide values for both parameters. If values are provided for both parameters, the Area Of Interest parameter takes precedence over this one.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
Overwrite Tiles
(Optional)
Specifies whether the images in the receiving cache will be merged with the tiles from the originating cache or overwritten by them.
  • Checked—All pixels in the area of interest will be replaced, effectively overwriting tiles in the destination cache with tiles from the originating cache.
  • Unchecked—When the tiles are exported, transparent pixels in the originating cache will be ignored. This results in a merged or blended image in the destination cache. This is the default.
Boolean
(Optional)
Specifies whether the cache content will be generated using the open tile package specification, and specifies the file format of the cache schema. This parameter can be used only when the Export cache type parameter value is Cache dataset.
  • Checked—The cache content will be generated using the open tile package specification (https://github.com/Esri/tile-package-spec). A tile package can be packaged to a zip archive as a tile package for offline workflows. The cache format will be Compact V2, and the cache schema will be stored in JSON format.
  • Unchecked—The cache content will be generated using a schema stored in XML format. Use this option to copy the cache to previous versions of ArcGIS Enterprise. This is the default.
Boolean
Derived output
Output Cache Path
The folder into which the cache has been exported.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
