An overview of the Caching toolset
The Caching toolset contains tools that work with map image and web imagery layers in ArcGIS Enterprise or with cached map or image services on a stand-alone server.
Tool |
Description |
Converts the storage of a map image layer or a map or image service cache between the exploded format and the compactV2 format. |
Creates the tiling scheme and preparatory folders for a map or image service cache. After running this tool, use the Manage Map Server Cache Tiles tool to add tiles to the cache. |
Deletes an existing map image layer cache, including all associated files on disk. |
Exports tiles from a map image layer cache as a cache dataset or tile package to a folder on disk. The tiles can be imported into other caches, or they can be accessed from ArcGIS Desktop or mobile devices as a raster dataset, independent from their parent service. |
Generates a custom tiling scheme file that defines the scale levels, tile dimensions, and other properties for a web tile layer. |
Imports tiles from a folder on disk into a map image layer cache. |
Updates the scale levels in an existing map image layer in ArcGIS Enterprise or in a cached map or image service on a stand-alone server. Use this tool to add new scales or delete existing scales from a cache. |
Manages internal data kept by the server about the built tiles in a map or image service cache. |
Creates and updates tiles in an existing web tile layer cache (in ArcGIS Enterprise or ArcGIS Online), map image layers in ArcGIS Enterprise, and cached map or image services in a stand-alone server. This tool is used to create new tiles, replace missing tiles, overwrite outdated tiles, and delete tiles. |
