Manage Map Server Cache Status (Server Tools)
Summary
Manages internal data kept by the server about the built tiles in a map or image service cache.
Usage
  • This tool is useful for rebuilding the cache status after you manually copy tiles into the cache directory or build tiles on demand.
  • This tool is the only way to build a status for a cache created with a previous release of ArcGIS Server or Portal for ArcGIS.
  • Rather than creating a status for the entire cache, you can alternatively use this tool to create status reports for custom areas of interest and scale levels. You do this by setting the Manage Mode parameter to Rebuild bundle status. The report is stored in a new file geodatabase named Status.gdb, specifically within a feature class named TaskStatus.
    Note that your cache directory also contains a Status.gdb that pertains to the entire cache and is updated when you use the other Manage Mode options for this tool. You cannot substitute a custom Status.gdb in this location.
Parameters
Label Explanation Data type
Input Service
The map image layer for which the cache status will be modified. You can choose it by browsing to the desired service in Portal or you can drag and drop a web tile layer from the Catalog pane Portal tab to supply this parameter.
Image Service; Map Server
Manage Mode
Specifies the action that will be performed on the cache status information used by the server.
  • Delete cache status—Deletes the status information used by the server.
  • Rebuild cache status—Deletes, then rebuilds the status information used by the server.
  • Rebuild bundle status—Creates status information in a new file geodatabase named Status.gdb in a folder you specify in the Output Folder parameter. This option is used when you want to create a custom status report for a particular area of interest or set of scales.
String
Scales
(Optional)
The scale levels for which the status will be modified. This parameter is only applicable when building a custom status using the Rebuild bundle status option for the Manage Mode parameter.
Double
Number of caching service instances
(Optional)
Defines the number of instances that will be used to update/generate the tiles. The value for this parameter is set to unlimited (-1) and cannot be modified.
Long
Output Folder
(Optional)
Output folder for the Status.gdb. This parameter is only applicable when building a custom status using the Rebuild bundle status option.
Folder
Area Of Interest
(Optional)
An area of interest (polygon) that determines what geography the status report will cover. This parameter is only applicable when building a custom status using the Rebuild bundle status option.
Feature Set
Report Extent
(Optional)
A rectangular extent defining the area for which the status will be built. This parameter is only applicable when building a custom status using the Rebuild bundle status option.
Note that the Area Of Interest parameter allows you to specify an area of interest that is nonrectangular.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
Derived output
Output Map Service URL
The output service URL.
String
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
