Manage Map Server Cache Tiles (Server Tools)
Summary
Creates and updates tiles in an existing web tile layer cache (in ArcGIS Enterprise or ArcGIS Online), map image layers in ArcGIS Enterprise, and cached map or image services in a stand-alone server. This tool is used to create new tiles, replace missing tiles, overwrite outdated tiles, and delete tiles.
Usage
  • This tool may take a long time to run for caches that cover a large geographic extent or very large map scales. If the tool is cancelled, tile creation is stopped, but the existing tiles are not deleted. This means you can cancel the tool if you run out of time and rerun it later on the same cache by setting the Update Mode parameter to Recreate Empty Tiles.
Parameters
Label Explanation Data type
Input Service
The web tile layer, web imagery layer, or map image layer whose cache tiles will be updated.
Image Service; Map Server
Scales
A list of scale levels at which tiles will be created.
By default, the scales listed in the tool dialog box are between the minimum and maximum cached scales for the service. You cannot change the cache scale range of the service in ArcGIS Pro.
Double
Update Mode
Specifies the mode that will be used to update the cache.
  • Recreate Empty Tiles—Only tiles that are empty will be created. Existing tiles will be left unchanged. This option is not available for web tile layers published to ArcGIS Online.
  • Recreate All Tiles—Existing tiles will be replaced and new tiles will be added if the extent has changed.
  • Delete Tiles—Tiles will be deleted from the cache. The cache folder structure will not be deleted.
String
Number of caching service instances
(Optional)
The total number of instances of the System/CachingTools service that will be dedicated to running this tool. If the default value of -1 is used, all the caching tool instances of the ArcGIS Enterprise setup will be used. Use a lower value to use fewer caching tool instances.
You can increase the Maximum number of instances per machine setting of the System/CachingTools service using the Service Editor window available through an administrative connection to ArcGIS Server. Ensure that the server machines can support the chosen number of instances.
When connecting to a stand-alone server, the default number of instances is equal to the value of the Maximum number of instances setting of the caching tool service.
Long
Area Of Interest
(Optional)
An area of interest that will constrain where tiles will be created or deleted. This parameter is useful for managing tiles for irregularly shaped areas. It is also useful when precaching some areas and leaving less-visited areas uncached.
If you do not provide a value for this parameter, the default value uses the full extent of the map.
Feature Set
Update Extent
(Optional)
A rectangular extent used to create or delete tiles, depending on the value of the Update Mode parameter. If both the Update Extent and Area of Interest parameter values are specified, the Area of Interest value will be used.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
Wait for job completion
(Optional)
Specifies whether the tool will continue to run while the cache job runs on ArcGIS Online or Portal for ArcGIS.
  • Checked—The tool will continue to run while the cache job runs on ArcGIS Online or Portal for ArcGIS. Using this option, you can request detailed progress reports at any time and view the geoprocessing messages as they appear. This is the default. It is recommended that you use this option in Python scripts.
  • Unchecked—A job will be submitted to the server, allowing you to perform other geoprocessing tasks. Use this option when you are building a cache automatically at the time you publish the service. You can also set this option on any other cache that you build.
Boolean
Portal URL
(Optional)
The URL of the portal.
String
Derived output
Output Map Service URL
The output URL.
String
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
