Get Layout Templates Info (Server Tools)
Summary
Returns the content of layout templates in JSON format. Layout files (.pagx) located in a folder are used as layout templates.
Usage
This tool is intended to be published as a geoprocessing task in a printing service. It is also used by the preconfigured
PrintingToolsservice.The output of this tool is a string formatted as JSON. The string is a list of available
.pagxfiles and the following information:The size and units of the page layout
The size of a map frame
- If there are multiple map frames on the layout, it returns information only for the map frame that is named
WEBMAP_MAP_FRAME.
The availability of the following layout elements:
Legend element
Title text element
Copyright text element
Author text element
Custom text elements and their names and existing values
North arrow element
Scale bar element
Group element
Dynamic text element
Table frame
Chart frame
The sizes are returned in the unit that is saved with the layout file.
A sample output JSON
[{ "layoutTemplate": "A4 Landscape", //name of the layout "pageSize": [29.7, 21], //page size "pageUnits": "CENTIMETER", //page units "activeDataFrameSize": [27.75, 15.91], //size of the map frame "layoutOptions": { "hasAuthorText": true, //is the predefined AuthorText available "hasCopyrightText": true, //is the predefined CopyrightText available "hasTitleText": true, //is the predefined TitleText available "hasLegend": true, //is the legend element available "customTextElements": [] //available list of custom text elements "mapSurroundInfos": [{}] //available list of map surrounds } }, { "layoutTemplate": "MyTemplatesWithCustomTextElements", "pageSize": [11, 8.5], "pageUnits": "INCH", "activeDataFrameSize": [6.65, 7.34], "layoutOptions": { "hasAuthorText": false, "hasCopyrightText": true, "hasTitleText": true, "hasLegend": true, "customTextElements": [ { "CityName": "Redlands" }, { "MapCenterCoordinates": ""}, { "SelectedParcelID": ""} ], "mapSurroundInfos": [ { "name": "North Arrow", "type": "CIMMarkerNorthArrow", "visible": true } ] } }]Use the same folder location that is used by the associated Export Web Map tool.
For more information, see Printing in web applications in the ArcGIS Enterprise help.
Parameters
| Label | Explanation | Data type |
Layout Templates Folder (Optional) |
The full path to the folder where the layout files ( |
Folder |
Layout Item ID (Optional) |
The portal ID (in JSON format) of the layout item that will be used for templates. Use the format |
String |
Derived output
JSON String |
A JSON formatted string. The string is a list of available |
String |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
