Send Email With Zip File Attachment (Server Tools)
Summary
Emails a file to an email address using an SMTP email server.
Caution:
This tool is primarily intended for use as a part of a Clip and Email/Data Extraction geoprocessing service. To this end, this script tool is contained in the Extract Data and Email Task model tool and is primarily intended for use by that model.
Usage
  • Ask your system administrator for details about an SMTP email server that you can use.
Parameters
Label Explanation Data type
To
The email address of the recipient.
String
From
The email address of the sender.
String
Subject
The text in the subject line of the email.
String
Text
The body text of the email.
String
Zip File
The file to be attached to the email.
File
Max File Size (MB)
The maximum allowable size of an attachment.
If you don't know what to use for Max File Size, check the attachment size limit of your SMTP mail server and the recipient email provider.
Long
SMTP Email Server
The SMTP email server that will deliver the email.
String
User
(Optional)
The user which will log in to the SMTP email server.
String
Password
(Optional)
The user password used to connect to the SMTP email server (if necessary).
String
Derived output
Send Email Succeeded
A Boolean indicating whether or not the email was sent successfully.
Boolean
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
