Assign Stream Order (Spatial Analyst Tools)
Summary
Assigns stream order values to stream features.
Usage
  • Stream order is a hierarchical measure that describes the relative position of stream reaches within a drainage network. The tool computes standard ordering methods directly and only from polyline stream features.
  • Downstream direction is derived from digitized direction, which is equivalent to the line geometry direction, from first vertex to last vertex, and connectivity is constructed from node-to-node connections.
  • To ensure the tool can accurately assign an order based on the selected method, ensure that digitized direction is consistent throughout the stream network.
  • The tool supports the following stream ordering methods: Strahler, Shreve, and Hack (Strahler, 1957; Shreve, 1966; Hack, 1957). The Strahler order of a stream increases when streams of the same order intersect. The Shreve order assigns order to streams based on magnitude. All links without tributaries are assigned a magnitude (order) of 1. Magnitudes are additive downslope. When two links intersect, their magnitudes are added and assigned to the downslope link. The Hack order of a stream increases by 1 with respect to the order of a stream to which it discharges. The main river channel is assigned a magnitude of 1, and all streams discharging to it are assigned a magnitude of 2, and so on.
  • None of the stream ordering methods support assigning order if loops, duplicates, or cycles exist in the stream network. In this case, order accuracy is not guaranteed, and the tool will return a warning.
  • If the Extent environment is specified, the tool will process and assign a stream order to all (partial or complete) stream features that fall within the specified extent.
  • See Analysis environments and Spatial Analyst for additional details about the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input Stream Features
The streamline features that will be assigned an order value.
Feature Dataset
Output Table
The output table containing the stream order values. The output table will contain the input features with a new order field populated according to the selected ordering method.
Table
Ordering Method
(Optional)
Specifies the method that will be used to order streams.
  • Strahler—The Strahler method, in which stream order only increases when streams of the same order intersect, will be used. The intersection of a first-order and second-order link will remain a second-order link, rather than creating a third-order link. This is the default.
  • Shreve—The Shreve method, in which stream order is assigned by magnitude, will be used. All links with no tributaries are assigned a magnitude (order) of one. Magnitudes are additive downslope. When two links intersect, their magnitudes are added and assigned to the downslope link.
  • Hack—The Hack method, in which each stream segment is assigned an order greater than the stream or river to which it discharges, will be used. For example, the main river channel is assigned an order of 1, all stream segments discharging to it are assigned an order of 2, any stream discharging to an order 2 stream is assigned an order of 3, and so on.
String
Output Join Layer
(Optional)
The output layer that will be created by joining the output table to the input stream features.
Layer
Environments
Auto Commit, Current Workspace, Extent, Geographic Transformations, Output Coordinate System
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
References
See the following references for additional information:
  • Hack, J., 1957, "Studies of Longitudinal Stream Profiles in Virginia and Maryland: US Geological Survey Professional Paper 294-B", p. 45–95, https://doi.org/10.3133/pp294B
  • Shreve, R., 1966, "Statistical Law of Stream Numbers", Journal of Geology, 74: 17-35
  • Strahler, A. N., 1957, "Quantitative analysis of watershed geomorphology", Transactions of the American Geophysical Union, 8 (6): 913-920
