Stream Order (Spatial Analyst Tools)
Summary
Assigns a numeric order to segments of a raster representing branches of a linear network.
Learn more about how Stream Order works
Usage
  • The output of Stream Order will be of higher quality if the input stream raster and input flow direction raster are derived from the same surface. If the stream raster is derived from a rasterized streams dataset, the output may not be usable because, on a cell-by-cell basis, the direction will not correspond with the location of stream cells.
  • The results of the Flow Accumulation tool can be used to create a raster stream network by applying a threshold value to select cells with a high accumulated flow. For example, cells that have more than 100 cells flowing into them are used to define the stream network. Use the Con or Set Null tool to create a stream network raster in which flow accumulation values of 100 or greater go to 1 and the remainder are put to the background (NoData). The resulting stream network can be used in the Stream Link and Stream to Feature tools.
    An analytical method for determining an appropriate threshold value for stream network delineation is presented in Tarboton, et al. (1991).
  • The Stream Order tool only supports a D8 input flow direction raster. D8 flow directions can be created using the Flow Direction tool, run with default flow direction type D8.
  • When the output raster format is .crf, this tool supports the Pyramid raster storage environment. Pyramids will be created in the output by default. For any other output format, this environment is not supported, and pyramids will not be created.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
  • References:
    Tarboton D. G., Bras, R. L., Rodriguez–Iturbe, I. 1991. On the Extraction of Channel Networks from Digital Elevation Data. Hydrological Processes. 5: 81–100.
Parameters
Label Explanation Data type
Input stream raster
An input raster that represents a linear stream network.
The input stream raster linear network should be represented as values greater than or equal to one on a background of NoData.
Raster Layer
Input flow direction raster
The input raster that shows the direction of flow out of each cell.
The flow direction raster can be created with the Flow Direction tool using the default D8 flow direction type.
Raster Layer
Method of stream ordering
(Optional)
The method used for assigning stream order.
  • Strahler—The method of stream ordering proposed by Strahler in 1952. Stream order only increases when streams of the same order intersect. Therefore, the intersection of a first-order and second-order link will remain a second-order link, rather than creating a third-order link. This is the default.
  • Shreve—The method of stream ordering by magnitude, proposed by Shreve in 1967. All links with no tributaries are assigned a magnitude (order) of one. Magnitudes are additive downslope. When two links intersect, their magnitudes are added and assigned to the downslope link.
String
Return value
Output raster
The output stream order raster.
This output is of integer type.
Raster
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Compression, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Pyramid, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
