Extract by Rectangle (Spatial Analyst Tools)
Summary
Extracts the cells of a raster based on a rectangle by specifying the rectangle's extent.
Illustration
Extract by Rectangle tool illustration
OutRas = ExtractByRectangle(InRas1, Extent(1, 0, 5, 5), "INSIDE")
Usage
  • Additional attributes from the input raster, if any, will be carried over as-is to the output raster attribute table. Depending on the property being recorded, some of the attribute values may need to be recalculated.
  • When a multiband raster is specified as the Input Raster (in_raster in Python) value, all bands will be used.
    To process a selection of bands from a multiband raster, first create a raster dataset composed of those particular bands using the Composite Bands tool. Then use the result as the Input Raster (in_raster in Python) value.
    The default output format is a geodatabase raster. If an Esri Grid stack is specified as the output format, the name of the stack cannot start with a number, use spaces, or be more than nine characters in length.
  • The center of the cell is used to determine whether a cell is inside or outside a rectangle. If the center is within the outline of a rectangle, the cell is considered fully inside even if portions of the cell are outside the rectangle.
  • Cell locations that are not selected are assigned a value of NoData.
  • If the input raster is integer, the output raster will be integer. If the input is floating point, the output will be floating point.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input raster
The input raster from which cells will be extracted.
Raster Layer
Extent
A rectangle that defines the area to be extracted.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
The coordinates are specified in the same map units as the input raster.
Extent
Extraction area
(Optional)
Specifies whether cells inside or outside the input rectangle will be selected and written to the output raster.
  • Inside—Cells inside the input rectangle will be selected and written to the output raster. All cells outside the rectangle will receive NoData values on the output raster.
  • Outside—Cells outside the input rectangle will be selected and written to the output raster. All cells inside the rectangle will receive NoData values on the output raster.
String
Return value
Output raster
The output raster containing the cell values extracted from the input raster.
Raster
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Compression, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
