Iso Cluster (Spatial Analyst Tools)
Summary
Uses an isodata clustering algorithm to determine the characteristics of the natural groupings of cells in multidimensional attribute space and stores the results in an output ASCII signature file.
Learn more about how Iso Cluster works
Usage
  • Iso Cluster performs clustering of the multivariate data combined in a list of input bands. The resulting signature file can be used as the input for a classification tool, such as Maximum Likelihood Classification, that produces an unsupervised classification raster.
  • When a multiband raster is specified as one of the Input raster bands (in_raster_bands in Python), all the bands will be used.
    To process a selection of bands from a multiband raster, you can first create a new raster dataset composed of those particular bands with the Composite Bands tool, and use the result in the list of the Input raster bands (in_raster_bands in Python).
  • The minimum valid value for the number of classes is two. There is no maximum number of clusters. In general, more clusters require more iterations.
  • To provide the sufficient statistics necessary to generate a signature file for a future classification, each cluster should contain enough cells to accurately represent the cluster. The value entered for the minimum class size should be approximately 10 times larger than the number of layers in the input raster bands.
  • The value entered for the sample interval indicates one cell out of every n-by-n block of cells is used in the cluster calculations.
  • You shouldn't merge or remove classes or change any of the statistics of the ASCII signature file.
  • Generally, the more cells contained in the extent of the intersection of the input bands, the larger the values for minimum class size and sample interval should be specified. Values entered for the sample interval should be small enough that the smallest desirable categories existing in the input data will be appropriately sampled.
  • The class ID values on the output signature file start at one and sequentially increase to the number of input classes. The assignment of the class numbers is arbitrary.
  • Better results will be obtained if all input bands have the same data ranges. If the bands have vastly different data ranges, the data ranges can be transformed to the same range using Map Algebra to perform the equation.
    Iso Cluster equation
    where:
       *Z* is the output raster with new data ranges.
       *X* is the input raster.
       *oldmin* is the minimum value of the input raster.
       *oldmax* is the maximum value of the input raster.
       *newmin* is the desired minimum value for the output raster.
       *newmax* is the desired maximum value for the output raster.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input raster bands
The input raster bands.
They can be integer or floating point type.
Raster Layer
Output signature file
The output signature file.
A .gsg extension must be specified.
File
Number of classes
Number of classes into which to group the cells.
Long
Number of iterations
(Optional)
Number of iterations of the clustering process to run.
The default is 20.
Long
Minimum class size
(Optional)
Minimum number of cells in a valid class.
The default is 20.
Long
Sample interval
(Optional)
The interval to be used for sampling.
The default is 10.
Long
Environments
Cell Size, Cell Size Projection Method, Current Workspace, Extent, Geographic Transformations, Mask, Output Coordinate System, Scratch Workspace, Snap Raster
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
