Finding the position from an input list meeting a specified criterion
Available with Spatial Analyst license.
There are two local tools that assign the position of the raster containing the cell value that meets a specified criterion relative to a list of values obtained from a series of input rasters: Highest Position and Lowest Position. The two possible criteria are the position of the raster with the maximum value for the input rasters and the position of the raster with the minimum value.
Example
The following table shows the values from each input raster for a particular cell location:
InRas1
InRas2
InRas3
InRas4
InRas5
InRas6
Example input values
Sorting these values from lowest to highest would result in the following table:
Value
Input raster
InRas2
InRas4
InRas1
InRas6
InRas5
6
InRas3
Sorted values list
Highest position
The highest value in the list, 6, is contained in the third input raster, InRas3.
Using the Highest Position tool, the resultant output value representing the position of the raster having the maximum value for that cell is 3.
Lowest position
In this example, there are two rasters that contain the lowest value in the input list, that value being 3.
Using the Lowest Position tool, the position of the first raster encountered with the value 3 will be reported. In this example, while both the second (InRas2) and fourth (InRas4) rasters contain the lowest value (3), the second raster is encountered first, so the output cell value will be 2.
