000054: Cannot create a projection file for <value>.
The tool failed to create or alter the input geodataset's projection definition. The feature dataset may be locked by another application or user, or it may be read-only.
Solution
Make sure the dataset is not locked by closing other applications that may be using it or ensuring that it is not being accessed by another user. If you are using a projection file (.prj) to define the projection, make sure it is formatted correctly. Finally, confirm that the output dataset is not read-only using the file system if you're working with a shapefile, raster, or geodataset in a local geodatabase. If you're working with an enterprise geodataset, review its permissions and change them accordingly.
