000072: Cannot process feature with OID <value>.
This error will occur in one of the following cases:
  • The geometry of the identified feature may be invalid or may be corrupted.
  • The identified record may contain a null or invalid value in a required field. The output for that record is skipped.
Solution
For the first case, run the Repair Geometry tool on the dataset containing the feature; the tool will correct invalid geometry whenever possible.
For the second case, review the skipped record in the input and make sure all required fields have valid values; then run the tool again.
