000132: The dataset already has a projection defined.
The tool is primarily used to define projection of a dataset that does not have any coordinate system set. However, the tool will execute. You will be warned that the execution of the tool will change the coordinate system.
Solution
If you want to change the coordinate system, use the Project tool instead.
