000222: An expression is needed if input layers are identical.
When the Input Above features are the same as the Input Below features, the Create Overpass and Create Underpass tools need to identify a selected set of features to be used for creating masks.
Solution
Use the Expression Builder dialog box to build a valid SQL expression. Use an existing feature attribute field to specify features or create a new attribute field to classify data.
