000379: The value may not be valid.
The error or warning has a different meaning depending on the context of the message.
For tools that work with attribute domains, for example, Assign Domain To Field, the domain specified is either invalid or does not exist.
For other tools, a keyword entered for a parameter is not a valid keyword.
Solution
For tools that work with attribute domains, for example, Assign Domain To Field, confirm that the domain used in the tool matches an available domain. Also confirm that the domain is appropriate. For example, if matched against a field, the type of field used must be consistent with the Domain field type property.
For other tools, a keyword entered for a parameter is not a valid keyword. Review the tool's help topic for a list of appropriate keywords.
