000442: <value> at <value> in <value>.
A problem was found with the geometry of a feature with the Object ID stated in the message. For a list of the geometry problems, see the Check Geometry tool documentation.
Solution
Fix feature geometry problems immediately, as they can cause incorrect results from analysis, as well as unexpected software behavior. To correct geometry problems, run the Repair Geometry tool on the feature class.
