000949: The input feature class does not contain the Unique ID field (<value>) that the input spatial weights matrix (<value>) was constructed with.
There is a mismatch between the input feature class and the spatial weights matrix file being used for this analysis. This mismatch means that results cannot be correctly matched to input features and/or that spatial relationships among features are not defined correctly.
Solution
Either specify a different unique ID field or re-create the spatial weights matrix file using the Generate Spatial Weights Matrix tool.
