001443: Failed to update job status for scale <value>.
The cache geoprocessing tool failed to update the Status GDB file while updating the cache. This can cause Cache Status to be out of sync with the service cache.
Solution
Verify that there is available disk space on the service cache directory. If the disk space is available, rebuild the status.gdb file using the Manage Map Server Cache Status tool with the Update Mode parameter set to Rebuild cache status.
