001490: The value <value> specified in the Parallel Processing Factor environment is invalid.
The Parallel Processing Factor environment value is invalid. Invalid characters may have been used.
Solution
Verify the following to ensure that the specified Parallel Processing Factor environment value is valid:
The value cannot be negative.
Alphabetic characters cannot be used; only numbers can be specified.
Decimals are only valid when a percent sign is used.
Characters cannot be used after the percent sign.
