001646: Input raster has wrong pixel type.
The input segmented raster must be UCHAR.
This may occur if you choose the wrong input raster or if the input was from third-party software.
Solution
Make sure you have the correct input raster. If your input is correct and still not UCHAR, you can make your pixel type 8-bit unsigned integer by using the Copy Raster tool.
