001953: The length of the selected domain exceeds the number of available bits remaining for inline attributes.
You are attempting to create a network attribute with the In Line parameter set to true and there are not enough bits available.
Network attributes that are created using the In Line parameter set to true are stored in the network topology. There is a restricted number of bits available for user-defined network attributes.
Solution
Create the network attribute with the In Line parameter set to false, or reduce the size of the attribute domain used.
