001971: Aggregated Lines for the SubnetLine Feature Class must be all or a subset of the Valid Lines.
The line asset group and asset types provided for Aggregated Lines must be a subset of the values provided for Valid Lines.
Solution
When you set the subnetwork definition for the tier for the first time, ensure that the line asset group and asset type values for the aggregated lines are a subset of the valid lines. If you're modifying an existing subnetwork definition, review the valid lines for the tier. You can review the valid lines in the network properties for the utility network layer. See Set or modify the subnetwork definition for more information.
