002630: The domain is being used as a default domain.
The domain that you are trying to delete is being used as the default domain for a field. You cannot delete a domain if it is in use.
Solution
Unassign the domain from any fields that are using it and run the tool again.
To learn how to discover datasets that are using a specific domain, see Identify domain usage.
