002632: Default value is invalid within the domain.
The default value you are trying to set for the field is not within the range of values that have been defined by the domain assigned to the field.
Solution
Review the domain that is currently assigned to the field. You can either choose a new default value that falls within the range of the domain or modify the valid domain values. If you're using a range domain, you can modify the range using the Set Value For Range Domain tool. If the domain uses coded values, you can add a new coded value using the Add Coded Value to Domain tool.
