002731: The dimension feature class will be upgraded in place. Backup data and understand usage limitations before upgrading.
The Upgrade Dataset tool upgrades the dimension dataset in place. It does not make a copy of the data before upgrading.
Once upgraded, the dimension dataset will no longer be available for use in previous versions. The following table describes how dimensions are supported:
ArcGIS version |
ArcGIS Desktop dimensions |
ArcGIS Pro dimensions 2.x |
ArcGIS Pro dimensions 3.x |
ArcGIS Desktop 10.x |
Full read, modify, and write access. |
Not supported. Any feature class in the same feature dataset will be read-only. |
ArcGIS Pro 1.x |
Read-only access. |
ArcGIS Pro 2.x |
Read-only access. |
ArcGIS Pro 3.x |
Read-only access. |
Full read access. Partial modify and write access. It may be downgraded based on symbols and dimension properties used. |
Solution
Ensure that you have a backup of your data before upgrading.
If you need to continue to use the dimension feature class in a previous version, make a copy, and only upgrade one version.
