002809: Field <value> in <value> is of an unsupported type for the output workspace.
Attribute fields in the input dataset are of a type that is not supported in the output workspace or data format. 64-bit Object ID fields or fields with the big integer, timestamp offset, date only, or time only data types are not supported in older formats such as shapefiles.
Solution
Do one of the following:
