002825: The fillet could not be constructed according to specs.
The fillet operation failed.
Solution
Verify that the input's spatial reference is valid and repair it if necessary. After the spatial reference is verified as correct, use the Check Geometry tool to evaluate whether the input contains invalid geometry. If geometry problems are found, use the Repair Geometry tool to correct the problems, and rerun the tool.
