002920: Exclude from application evaluation must be enabled.
The attribute rule Exclude from application evaluation parameter must be checked when the following conditions exist in the script expression:
The NextSequenceValue Arcade function is used for sequences
The following dictionary keywords are used that require client side evaluation
calculationRequiredvalidationRequirededit
See Attribute rule dictionary keywords for more information.
Solution
When adding an attribute rule, ensure that the Exclude from application evaluation parameter is checked or set to true.
