002977: Values for '<value>' = '<value>' are not found in input datasets. Locator will be built with spatially restored '<value>' values in this case.
The values referenced in the message did not have a corresponding Join ID value in the input datasets. If the locator to be created is a multirole locator that includes a polygon feature class that is assigned to a primary administrative zone role and includes the missing attributes that could not be joined, the missing values will be restored spatially.
Solution
If you expect the corresponding attribute value to be missing from the locator or that the value that is spatially restored is correct, this warning can be ignored.
Confirm that the Join ID value is correct or that the records that should correspond to the Join ID value have the correct value.
