003386: The change tolerance is too small and will not be used in processing.
The process can only be performed with a value greater than the x,y tolerance of the input data. The tool will proceed with the default value of 0, meaning this process is not performed.
Solution
Increase the Change Tolerance parameter value to a value greater than the x,y tolerance of the input data. For more information about change tolerance, see to the Detect Feature Changes tool documentation.
