003506: At version <value>, the "<value>" tool's "<value>" parameter's filterType has changed.
The analyzer identified a compatibility issue with a tool parameter. The parameter's filterType value is not consistent at the current version and the selected target version.
The following are examples of filters:
File type—A list of file extensions, for example,
.xml,.xls, and.txt.Feature type—A list of feature class types, for example, Point, Line, and Polygon.
Field type—A list of field types, for example, Short, and Long.
Range—A minimum and maximum value, for example, 1 to 100.
Value list—A list of string or numeric values, for example,
UP,DOWN,LEFT, andRIGHT.
When a filterType compatibility issue is reported, the parameter has typically changed from no filter to including a filter (or from including a filter to no filter).
Solution
Use the target version of the software to review the processes in model and script tools that were identified with compatibility issues. Review the version-appropriate tool documentation, run the model or script tool, and review the output to confirm it is acceptable.
See the Analyze Toolbox For Version tool documentation for more information.
