003527: Parameter <value> is not present on the <value> tool and has a value which is not the default, the tool cannot be converted
The analyzer identified a compatibility issue with a tool parameter.
A parameter is missing from the target version, and the parameter value is not the default value (default values are typically backward compatible).
Solution
This compatibility issue cannot be addressed automatically. Try the following:
Use a later target version in which the compatibility issue is not present.
Modify the model or script tool to use an alternative, if one exists, to the problematic tool or parameter.
Using the Save Toolbox To Version tool, uncheck the Error on missing required parameter to remove the parameter from the output toolbox. Review the results from the output toolbox.
