004008: Unable to run this operation because another session is currently running the same operation.
Only a single session can run the enable or disable network topology operation at a time. The operation you attempted is unable to run because another session is currently running an enable or disable network topology operation.
Solution
Review the utility network properties to confirm whether the network topology is enabled or disabled. Allow the current operation to complete and if necessary, re-attempt the enable or disable operation.
