004046: Circuit(s) not found.
No circuits were found in the Circuit Name parameter value or from the specified starting point. This error may also occur when a circuit with the same name exists, or when features with an asset type assigned the Circuit Point category are found but a path cannot be found between the starting point and stopping point.
Solution
Do one of the following:
  • Ensure that the Circuit Name parameter value in the circuit trace is valid.
  • Use a Path trace to confirm that a valid path exists between a circuit's starting point and stopping point. This can be completed from the Find Circuits pane for a specified circuit or by using the Trace tool with a starting point and a stopping point placed on the features that define the start and stop for the circuit.
