004201: One or more problems were discovered with resolutions defined in the Error Resolution table.
The Error Resolution table has errors that prevent the Apply Error Resolution tool from being run.
Solution
Review the list of errors and correct the rows based on the error using the following guidelines:
DeltaX,DeltaY,DeltaZ,DeltaStep, andActionClassGroupTypefields should not be configured with an error action value of Do nothing.DeltaX,DeltaY,DeltaZ,DeltaStep, andActionClassGroupTypefields should not be configured with an error action value of Delete all.DeltaX,DeltaY,DeltaZ,DeltaStep, andActionClassGroupTypefields should not be configured with an error action value of Delete all but first.A
DeltaX,DeltaY,DeltaZ,DeltaStep, orActionClassGroupTypefield is required with an error action value of Update all.A
DeltaX,DeltaY,DeltaZ,DeltaStep, orActionClassGroupTypefield value is required with an error action value of Update all but first.The
ActionClassGroupTypeclass must be the same as the source with an error action value of Update all.The
ActionClassGroupTypeclass must be the same as the source with an error action value of Update all but first.An
ActionClassGroupTypevalue is required with an error action value of Create.The
ActionClassGroupTypevalue must be a device or junction with an error action value of Create.DeltaX,DeltaY, andDeltaZfields are required when aDeltaStepvalue is specified.The action is not valid.
