Apply Error Resolutions (Utility Network Tools)
Summary
Implements the error resolution actions defined in the ErrorAction field of the Error Resolutions table. This table can be created using the Analyze Network Data tool and modified to define the action that will be taken to address various common error types. The ErrorAction attribute field value defines the type of change that will be made in the utility network.
Usage
The network topology can be enabled or disabled.
The following requirements must be met when working with an enterprise geodatabase:
When working with an enterprise geodatabase, the Input Utility Network parameter value must be from a database connection established as the database utility network owner.
The input utility network must be in a nonversioned state to run the tool.
Parameters
| Label | Explanation | Data type |
Input Utility Network |
The utility network that will be updated with the edit actions defined in the Error Resolutions table. |
Utility Network Layer |
Resolution Table |
The error resolutions table defining the edit actions that will be applied to the utility network classes to resolve errors. |
Table View |
Output Location (Optional) |
The output folder where the folder specified in the Output Name parameter will be created. |
Folder |
Output Name (Optional) |
The name of the output folder. This folder contains output |
String |
Derived output
Output Utility Network |
The updated utility network. |
Utility Network |
Output Folder |
The output folder containing |
Folder |
Environments
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
