010419: Unable to build the attribute table of <value> as required by the operation.
A raster attribute table is needed for analysis, but one was not found. During the operation, an attempt to create one internally was made, but a problem was encountered, causing the process to fail.
Solution
Check that the dataset and your workspace are valid and that you have correct permissions.
You can also create a raster attribute table for the input raster with the Build Raster Attribute Table tool.
