030351: The network dataset schema has not been upgraded to the current software release version. Templates created from this network may be unusable.
The network dataset was created with an earlier software version. Because the network dataset schema has changed since the network was created, you may not be able to create a new network dataset using a network dataset template created from this network.
Solution
Run the Upgrade Dataset tool to upgrade the network to the latest version before creating a template.
Upgrade the geodatabase containing the network dataset to the current release using the Upgrade Geodatabase tool.
