030354: The input feature class has a CurbApproach field, but it is not of type LONG. This field will not be used to influence locating behavior.
When calculating network locations for a feature class using the Calculate Locations tool, if the input has a CurbApproach field, the values in this field may be used to influence locating behavior. However, if this field is not a long integer, it cannot be used and will be ignored.
Solution
Change the data type of the CurbApproach field if you want it to be used in locating. Otherwise, ignore the warning.
