030359: The input feature class has a Status field, but it is not of type LONG. This field will not be updated by the tool.
When calculating network locations for a feature class using the Calculate Locations tool, if the input has a Status field, the field values will be updated to reflect each row's locating status. However, if this field is not a long integer, it cannot be updated and will be ignored. The inputs will still be located as normal.
Solution
Change the data type of the Status field if you want the tool to update it. Otherwise, ignore the warning.
