030385: The network dataset uses Field Script or Element Script evaluators configured with the VBScript language. Templates created from this network may be unusable.
Field Script and Element Script evaluators using the VBScript language are no longer supported as of the ArcGIS Pro 3.5 release. Because you can no longer create or build a network dataset with these types of evaluators, any network dataset templates created with this tool will not be usable with the current software.
Learn more about the types of evaluators used by a network
Solution
Update the network dataset's evaluators to the Python language, rebuild the network, and create the template again.
Learn how to migrate VBScript evaluators to Python
